Ed1
June 28, 2005, 4:29pm
1
anyone got one I can borrow/rent?
my car’s rich soo it needs to be timed. it’s causing my engine to stall/choke for some reason when my boost goes up
well that’s what I’ve been told… lol it could be either the wastegate shutting off too early… but I dunno… I need it timed for sure…
ty
ed
What motor?
Who told you timing is the issue?
Ed1
June 28, 2005, 5:18pm
3
well timing issue was told from a s12 driver…
the wastegate probabiliy was from a PI manager that used to own a s12 (he test drove it too)
rich b/c the sparks were carbon black and I smelled gas from the exhaust?
Still doesnt tell me what motor it is?
Ed1
June 28, 2005, 5:41pm
5
whosp I forgot… sry… ca18et
^^^ I wonder if that manifold works on a KA24E?
Besides that, check timing but I don’t think your issue is there.
Is the only problem your having is it running rich?
How’s your O2?
Ed1
June 28, 2005, 7:01pm
7
well… it idles rough… a bit shaky…
as for the o2 sensor … I’ll be checkin it tomorrow mornin
luka
June 30, 2005, 2:13pm
8
I was wondering… how do you ground out the ECU so that it only runs on base timing?
I just baught a timing light and wanna try the thing out.
check for boost leaks, a little leak will cause the car to run rich and idle shitty
Ed1
June 30, 2005, 5:35pm
10
can the boost leak cause the car to stall when the turbo kicks in…?
no bov and IC just standard wastegate
