Traded in the 335 for a silverado, decided to debadge it and clean up the rear a bit.
I tinted the tails
I love how it looks during the day, but the bulbs are dim at best. With the horrible storms we get during the summer, I dont want to risk really dim running lights.
Does anybody have any experience with a worthwhile bulb. (I only did 2-3 coats of nightshades on them and then 3 coats of clear, but they’re pretty dark)
Worst case scenario I’ll buy stock tails or I’ll put one of those LED strips between the tailgate and bumper.
---------- Post added at 12:36 AM ---------- Previous post was at 12:35 AM ----------
Bottom line I dont want to buy junk thats not going to help and piss away 30 bucks on cheap bulbs. Especially if they dont look any brighter than stock
I had very dark tinted tails (6-8 coats) in the past. I ran led bulbs and had no issue with light output. http://www.superbrightleds.com is where I got mine.
Z34, a ton brighter than stock. As for the fast flicker I never had an issue with that either. However I have heard of this happening and it is as easy as a relay.
The only time you would get problems with hyper flash is if you had weaker LEDs. Since an LED draws a really low amount of power (compared to regular bulbs) you end up getting the hyper flash since the circuits not load balanaced, but if you got a replacement LED bulb that had higher lumen output and consumed power closer to the stock bulb, you won’t have that issue.
I have never had any LED bulbs, so I can’t really comment, just wanted to provide some info on the hyper flash!
