I installed the torque converter onto the transmission, but it doesn’t want to spin freely, it keeps binding and you can hear grinding inside. I think I may have screwed it up while bolting the tranny to the engine. I think it wasn’t seated all the way on the transmission and it messed something up.
It should spin freely on the tranny, correct?
Brian - do you still have my stock converter I gave you? I was going to use it temporarily so I can get the engine back in and fired up.
The last time I put it on, it definitely went on all the way. I’m not sure about the first time though. And it made some nasty sounds when I tightened up the bellhousing bolts. I took it right off, but the damage may already have been done.
But if I have to send the torque converter out for repairs it could be a few weeks before I fire it. And the only way to prime the system is to take the intake manifold back off.
As long as it doesn’t hurt anything I was just going to run for a little while to diagnose any problems.
