Transmission toast?
So I was driving to London from Kitchener today and I got on the 401, I noticed my clutch was kinda weak (Broken Master), i tried to shift to 5th and my pedal went completely limp and i got some grinding. I proceeded to pump the pedal a few times and i got some pressure from the pedal, when I trieed to put it back into 5th it seemed like there was nothing there.
Fast forward to London, I,m stopped at a light and decide to test the tranny for the rest of the gears, when i put it in reverse it got stuck and no matter where i put the shifter I am in reverse.
So is the tranny toast or am i just stuck?
wow, did you do any rough driving before?
whereas the tranny might of been affected…:S
need more detail, how were you able to get back or reach destination?
only street driven, I made it home in 4th gear when i tried out reverse i guess the tranny jammed up because now everything is reverse
