is the exhause inlet flange on a t25 turbo the same as a flange on a 14b turbo?
what style t25? if its an aftermarket turbo(garret,etc.) then no.
ok, but a stock dsm t25 will??
dont quote me on that, but both are mitsu turbos, and both are used on the DSM’s, so i wouldnt doubt it if they would be the same. i doubt they used a different manifold for each turbo
Edit: Garrett T25 =/ 2g DSM T25. The 2g exhaust manifold is interchangeable like Skrapper said.
2g (t25) manifolds are direct bolt up’s for 1g(13b and 14b) manifolds, so yes, for the exhaust inlet side and I beliver the outlet (o2 housing side) is the same as well.
The cold side is very different though.
To add to this…Garrett T25 is the turbo however the exhaust housing is a Mitsu housing like used on the 14b…
There are a ton of T25s out there with different exhaust housings. If you are trying to swap a t25 inplace of a 14b you need the Mitsu t25
