Unknown problem possibly related to aftermarket clutch?
Hey, Let me know if anyone can help. I had to replace my clutch about 4 months ago. The stock clutch was replaced with a racing clutch from a company called “BULLY CLUTCHES” Bully Performance/Racing/competition Clutch http://www.bullyclutch.com/stage1.html . I went to AUTOMOTIVE WAREHOUSE (maybe that was a mistake). I put the clutch in with with an original brand new fly wheel from Infiniti. A week after i put the clutch in i noticed that when i put the car in reverse (clutch pedal all the way down) the gear was grinding. Almost as if you stuck a pen in a ceiling fan. The problem arises intermittantly and its now doing the same thing but not as bad going from 1st to 2nd gear as well. Seeing that it just started happening after i replaced the clutch i was wondering if that had anything to do with it. Anyone?
I wouldnt mind replacing the clutch again with possibly a better brand. Just wanted to find out what it might be first. No sense in buying a new clutch if it isnt even the problem.Any suggestions/solutions/brands etc.
Dan… you suck.
anyways, likely not the clutch. sounds like some fggt owned your car before you bought it and rammed through the gears too hard… Dan needs new tranny yes? Maybe just a fluid change and some synco-mesh
we’ll chat.
Bing I hate you. We’ll do lunch.
