okay so none of the USB ports work on my laptop. I had ryanmcell take a look at it for me and according to him it might be something bad on the motherboard. The ports are getting power but everytime you plug something in it says device not recognized. Does anyone have any experience with this kind of issue or know of a place to fix it that’s reasonable in price?
second - try deleting the drivers for the usb ports. then restart the computer and let windows reinstall the drivers. i’ve had this happen before, and it usually turned out to be a bad driver.
Vista Home originally installed.
-all usb devices install as unknown device.
Re-format.
XP installed
-when USB drive installed OS freezes, manual reboot and nothing in Event Viewer regarding this. Try to use manual driver, won’t accept and still freezes on insertion of USB device. Plus XP drivers were never released for this model laptop, so back to Vista.
Re-format
Vista Ultimate & all chipset & device drivers installed.
-USB device inserted & installed as unknown device
Tried numerous USB devices 1.1 & 2.0 (printer, flash drives, memory cards, mouse, keyboard, etc.) manually forced drivers in and still shows up as Unknown device. Insert usb device into my Vista Ultimate machine and device installs perfectly.
From research it appears this is a problem with Toshiba Satellite Series and a lot of people have this issue with no known work around other than returning to Toshiba for a replacement unit which unfortunately Anthony can’t.
try uninstalling chipset or if nogo try reinstalling xp with no chipset i had this happen before on my current computer had to reinstall a few times to get it right i had a clashing problem between my chipset and audio drivers should not have but i did so give that a try if not call toshiba india and let them know what you have tried and get thier input and if it is still in waranty let them fix that ish
