Hi all. Can someone tell me how to remove the vacuum? hose that runs into the valve cover.
awh… pull it off perhaps ?
I’m surprised he has a license.
Sorry couldn’t resist.
I took more force to pull out than anticipated, so I decide to put it before the esteemed panel just to make sure I’m not doing anything wrong, or maybe be enlightened of a better way. Insults aren’t really necessary.
Use needle-nose plyers to squeeze clamp well out of the way, then pull & twist hose loose and off.
If it’s really that stubborn, you could wrap the hose in a towel and use larger pliers to tug it off.
