Most people are just swapping their ring over onto a new diff without resetting their pinion depth and backlash. It’s probably close enough to not really matter, but I would say that most people don’t set their diff up properly after installing an LSD. I don’t see how the OEM spacer could wear down. You’ve either thrown a bearing in there (probably a bearing whining, not gears), or there’s something cranky in your transmission. Depending on the bearing, it could be walking enough to induce some gear noise, but I would hazard a guess that it’ll be a bearing gone, not gears…
(ONLY DO THIS IF YOU TRUST THE OTHER PERSON AND CAN DO IT SAFELY!!!)
If you put the rear up on blocks, so the wheels can spin, and have someone run the car up to speed where the whining is starting you can listen to figure out which bearing it is before you even pull the case.
Block up rear end, and chock front tires
Grab a long screwdriver (stethoscope if you have one)
Have someone run the car up to whatever speed the whine is the worst at.
Put handle of screwdriver to your ear, and touch the other end to the front of the diff case by the pinion, and at the sides by the output flanges. You should hear the bearing making all sorts of evil noises, and this will allow you to hopefully pinpoint which bearing it is.
That should help you narrow things down before you start pulling everything apart.
If you die doing it, it’s not my fault, but this is a very accepted, and common practice for pinpointing a bad bearing. It’s much easier on a 2-post hoist.
For illustrative purposes only…
41301 is the part you get when you buy an aftermarket LSD. That’s the part that actually transfers the power out to the wheels.
The Ring gear and Pinion gear are unlabeled in that picture, but I hope you know which two those are.
The measurement Face and I are refering to is the depth/engagement of the pinion gear onto the ring gear, and the subsequent backlash between the two gears. It’s a fairly critical measurement when installing a differential, but one that most people overlook. Most people, I would imagine, just pull the differential assembly out of the case, unbolt the ring gear, bolt it onto the new diff, and reinstall it into the case. Most forumites in my experience though, just swap entire housings when their diff dies, and never bother fixing the actual issue.
---------- Post added at 11:11 AM ---------- Previous post was at 11:08 AM ----------
http://www.kaazusa.com/lsd_nissan.html
The image at the top of their chart is what you get. It’s an exploded view. All the disks are the clutch packs that engage the axles and transfer power out. The gears in the middle are your spider gears (what gets welded in a ‘welded diff’)… All that junk gets bolted to your ring gear, and your axle shafts engage on either end. You get the diff itself, and possibly new hardware.
