Wastegate Problem/Startup Problem
I have a redtop with a stock T25. I think that the bladder inside he wastgate actuator has burst. The rod the goes into the back of it is loose inside the actuator and actually rattles on the round outside peice of the actuator. My car also has a hard time running on start up, it wilp stall if I do not give it a bit of gas. It also does not have a smooth idle and is running kind of rich right now. My question is, if the bladder has ruptured would this cause a vaccuum leak and could that be the problem that could be causing my car to have trouble starting and not running properly??
Thanks in advance for any help anyone might be able to give.
Corey
