Water pump bolts
Need to replace my water pump bolts - apparently some moron must have forgotten to put thread sealer on them when the pump was changed last time and they’re rusted. :redface: But GM doesn’t list part numbers or anything about them. Anyone happen to know the thread size? I guess I’ll just have to find them somewhere. Are they the black oxide coated bolts or just plain steel?
:doh:
i got some or can get u new gm ones!
If you can get me new ones that would be good. Don’t have part numbers, but I found that they’re 3/8"-16 threads. (4) 4" and (2) 2".
I also need one of the plastic push-plugs that holds the radiator shroud on, and 4 of the ones that hold the cowl on.
I’ll see if there’s anything else and PM the list to you. Might as well buy it off you instead of Harper.
Found the part numbers.
9440073 - quantity 2
9423592 - quantity 4
Harper’s sucks. “They don’t have a bolt kit for that. There’s not even any numbers listed for it.” Ass clown.
Any parts I need will come from JJ’s! Even if it means driving half an hour for a little piece.
