To start off, the fluid level is fine
OK so I have no idea how to explain this properly but I’ll give it my best shot.
Basically, the power steering on my coupe beater is acting weird. It’s been doing this for quite a while now.
I don’t believe there are any leaks.
I’m not 100% certain of the circumstances that this will happen, but I can re-produce the issue everytime by doing the following:
When I’m turning, if I’m just cruising or not accelerating with much throttle it feels generally fine but if I give it a decent amount of gas and accelerate through the corner everything stiffens up really tight… to the point where if I don’t let off the gas the wheel will stay turned indefinitely until I either force it back myself or if I let off the gas.
basically it seems like if the motor is under load (or perhaps the ps is under load for the cornering?) the power steering is dead, or maybe not completely dead but at least acting up in some way… like I said its hard to explain.
I thought maybe someone would have some insight?
