I have to weld a couple things to my stock cast exhaust manifold.
- 1/2" thick T3 flange
- Wastegate flange
My concern is the turbo flange. It’s going to be welded to my current T3 flange to act like a spacer. Or, instead of welding it on should I use extended studs and an extra gasket? If I do weld it, what is the best way to keep it from warping?
The wastegate is a different story, I have to drill a hole in the top of the manifold and weld in a pipe with flange. I might outsource this to Hank or something.
Weld the flange on AND use extended studs. Just no double gasket. Too much movement and it’ll likely blow out.
