Ok so heres the story.
I had my swap done on saturday through to sunday night. Went successfully. Got the new ka24de in and the 5speed tranny (automatic to manual). We had to use my old hicas power stearing pump from my old ka and put it on the new ka…(so we put a hicas pump on a non hicas engine…which shouldnt have mattered). Yes we replaced the driveshafts and what not…etc.
So with everything in and finished im off…about 5 minutes into the drive my i notice the hicas light has come on, and my speedo doesnt work…now i will be snapping on someone who sold me this speedsensor seeing as how my cruise control and kilometers dont work aswell. So the hicas light is on and i didnt think to much of it seeing as how we had to drain the power stearing fluid and refil it so i figured it would fix it self.
Im about 5 min away from my exit and i look down to my cluster to notice my engine temp wayyyy up and overheating…not only that, but my buddy noticed faint bits of smoke coming from the passenger side, mid way up the hood. I pull off and into the walmart parking lot. I turn off the car, and pop the hood…keep in mind freezing winds, 10 30 at night, and its fucking cold. Smoke comes out as i open the hood, i look over to the coolent and its empty…all of it has overflowed and evaporated. I let the car cool down after about 20 min and manage to get it home by throwing in some coolent from the closest gas station. As im turn on the car and drive away, my powerstearing has no longer become functional…fuck. I get home non the less…the next day we diagnose the problems and come to find that my powerstearing belt is chewed up now. After thinking it over he’s come to the assumption he had put the belt on the outer rivet of the hicas pump rather than the inner rivet causing the belt off course, thus shredding it and disallowing both the ps pully, and water pump pully to turn…thus overheating the car.
So we he gets the new belt on, and in the right position this time, and we fill up all fluids…coolent, ps…etc. Drive it around the block for about 5 minutes and everythings fine. I let it idle in my driveway for about another 5 minutes. After he leaves im sitting in the car and about to put it into my regular spot on the drieway, and i happend to look down to see my hicas light on…and just at that moment does my deck decide to turn off than on, and my cluster lights dim. I pull into my spot and turn the car off…as i try to turn it back on it felt as if the battery was dead…tried again and no luck…wouldnt turn over. It ticked but wouldnt turn over.
I called him and we talked it over to come to an assumption it may have been the power stearing pump…which i now am in disbelief because of one reason. About an hour ago i decided to go out to the car to see what exactly the ticking noise was, weather it was the alternator or the battery. Couldnt have been the batter because my lights would still come on. So i turn the key, and to my confusion it turned over without any hesitation. Man was i confused. So i turned it off right away, and started it again…and again, no problem. So i let it idle…poped the hood and examed to see if anything strange was arising…nothing, seemed fine. No hicas light, no power stearing noises, belt that was chewed was in order…everything was fine. So i drove it around for a bit…about 10 minutes of constant driving and rpm changes…and it seemed fine, didnt overheat and at no point did the hicas light come on. So i toped up the ps fluid just incase and it seemed alright, no leaks under the car nothing.
Now im still confused as to WHY all of a sudden after fixing the problem my deck turned off than on, my lights dimmed, and after turning the car off…it wouldnt turn over…any ideas?
