I’ve been looking into getting some aftermarket gauges. After reading through some of the previous posts I have seen that autometer and megan were 2 of the more comon gauges but it seems people were not satisfied with them.
I’ve read that they recalibrate and don’t work properly(specifically autometer) so would an electrical gauge be the only solution or does another brand of mechanical not have this problem?
Im specifically looking for a/f, boost and oil pressure what brand would be good to go with and not have to spend tons of money?
Anyone have any experience with JDM West’s megan gauges?
Lets hear what you guys are using and some input on them. Thanks
Air fuel in pointless unless you are running a wideband sensor. I have the greddy ones adn they are nice, accurate and easy to read. However not really that cheap. Between 100 and 175 each. They are all electrical tho
Personally I would recommend a wideband display of some kind. PLX stuff is cheap and works really well. AEM makes a guage style wideband that has the LED setup like a regular air fuel guage aswell as the digital display.
Im using autometer and the Boost/Vac guage seems to be the guage that i have seen fuck up at least twice, havent had any problem with oil pressure, coolant temp, or A/F guages though.
Have you had to replace the gauge each time or is there a simple way to fix it?[/quote]
The needle moved, so the the guage is off by 7 psi now, i just use it as a reference point to see whether im getting boost spikes when seting up the Boost controller. Im too Lazy to get it exchanged.
DONT TOUCH AN AUTOMETER GAUGE FOR BOOST! mine went funky with the calibration, and then it started making some stupid sound that i couldnt figure out for sooooooo long… junk junk junk junk junk junk junk junk! cant say it enough junk junk junk junk junk junk junk.
Id stay away from the Megan guages. They are cheap but for a reason. I have them in boost, water temp, oil temp, oil press, and EGT, but both of my temps dont work due to the fact the the megan temp senders suck. And yes they really really suck to read during the day.
Thanks for all your help guys! I think im going to go with autometer boost, oil pressure and water temperature. But for the boost I will get an electrical and then the others I will just get mechanical ones.
