What happens when Inhibitor/Range Switch is no good?
Here are the symptoms im having
1: Car will not crank over [will only start when i bypass the inhibitor, like i ran a wire from the ignition start wire right to the starter]
2. The car does not move in any gear, D,R,1,2 No movement it just revs like its in neutral.
3. The Linkage from the shifter to the inhibitor is good as you can see it move when you put it in different gears but nothing engages.
would the range/inhibitor switch affect if the transmission engages into D,R,1,or 2?
