ok, if you put an originally abs equiped brake system (s14 front spindle,caliper,rotor) on a non abs equiped car (s13) with the abs line unattached will it effect anything negatively?
do i remove the sensor? just plug the line? just cut the line? are the brake pads for abs or non abs the same size?
ive done this…i just didnt have the abs hooked up didnt seem ot cause any problems for me…and i do believe the pads are different but im not 100% on that
