I have this wierd sound coming from my rear left side wheel.
it sounds like a rubbing sound but the wheel clears the wheel well and all that stuff. at first i thought it was a bearing but it sound the same at every speed, can it be a warn bushing?
you got hicas?
no hicas for me
i had my dust shield rust off and rub on the brake disk…sounded bout the same at any speed
im going to check this tomorrow.
thanks
i kicked both dust shields off goin down the 400 at seperate times but it was annoying as hell till i did
well the noise seemed to stop which is good because it was damn annoying.
thanks for your imput guys much appriciated
I have HICAS and i have the same noise? How do I get rid of it?
ok the sound is back and it only goes away when its raining outside
so im guessing its a bushing
Answer my question too ^^
next time your driving around, and you hear the noise drive for a bit more then pull over, and put your hand near the brakes, if you can feel heat coming off of it (without touching) (also this is with just normal braking) and if you can smell a horrible smell, then your brakes are seizing and thats what could be causing it
its not the brakes, but tomorow im taking off the wheels and checking everything so ill know the answer, but im sure its the dust plate. oh well
thanks
