SOLD!
are these for a s14 or s13?
Neither, these are generic parts from Wilwood.
so what car do they work on then?
:bonk:
they only work on JDM cars.
Like others have said, these are a universal setup. They COULD work on almost any car if you can come up with a way to mount and plumb them.
Dan
Sick set up!
hmm interesting… and here i was just contemplating of doing this a month ago… my brake setup doesn’t work well with any oem mbc setup as is… i’ll let you know in a week or so…’
where exactly are you? I am guessing not canada (with the sites being joined). I am assuming 14502 is a zip code for somewhere in NY?
I’m seeing 3/4", 1" and 7/8"… which is which pictures are confusing lol. I’m guessing 3/4" is the clutch one.
Yeah, he’s in NY near Rochester.
The 1" and 7/8" are paired on a balance bar for tuning your brake force/pedal in. The 3/4" is the clutch.
Hope you don’t mind me answering for you Dan.
Ya, Mike is right on the bore sizes. I guess I should be more clear on exactly what is what other than just pics (although I sorta thought it all made sense).
No problem Mike, thanks for the reply.
Dan
Not to sound ignorant but the MBCs on the brake pedal and clutch pedal are easily interchangeable with other wilwood mbcs correct? Just wondering as I may need to get a different second one. I’ve been actually told for my brake setup that two 3/4 on a balance bar may be just right for the brakes but I would still be interested. We shall see.
Correct. Pretty much any Wilwood, Tilton, CNC Brakes, etc master cylinder with the correct mounting hole spacing will work.
Dan
Also what are the pedal lengths and ratios?
Sorry it took so long to get back to you.
Brake pedal p/n is 340-1278, it has a 7:1 ratio and a 11.91" length
Clutch pedal is p/n 340-1290, also a 7:1 ratio and a 11.86" length.
All the specs can be found here: http://www.wilwood.com/PedalList.aspx
Dan
Bump.
Going on ebay this week.
Dan
