floor mount pedal assembly
Just wondering if anyone on this board ever used it . I seen many company making floor mont clutch and brake pedal . The advantage I see in these idem is the fact that master cylinder ( clutch and brake ) are right behind the pedal . That create a lot more room in the engine bay .
Like I say , just wanted to have feed back from other members .
I’ve never heard of anything like that to tell you the truth. :dunno:
I have, and have looked into them due to my turbo setup my turbo is
quite close to my brake master (5mm of clearance) The only issue I have
with them is they will cause you to sit further back which makes you
further from your steering wheel and shifter. Also if you mount them like
most universal companies want you to the brake sticks out an inch past
the throttle which is awful for any drivability. You would have to do some
serious custom work to either cut out and tub the foot well to fit them
further back or make a custom bracket to bring forward the throttle.
Have you found any specific kits for the S13 or S14?
yea deffaintly have you found anything for the s13?
id be interested to see how much it would be complete…
GT
Sorry for the late reply guy , I contacted a company call tilton and they say there kit are universal and should fit the s13 with no problem .
www.tiltonracing.com . I personnaly gave up the idea to tell you the truth .
Tilton makes some sick shit but are you willing to fork ou $1000 for that pedal assembly?
