on a RWD,
what’s a good way to keep the wheels down in winter,
and have traction?..
I’ve heard about putting a shitload of bricks, or cinder blocks in the back,
any other good ideas?..
-1
on a RWD,
-1
I just put on some really good winter tires (ultra grip gw3’s) and drove according to the conditions. . .remember you want handling and braking the most, which is up front. . .
Get winter tires. You don’t need weight in the back. Go easy on the throttle and all will be well.
B-Wurm
bricks in the back will help with traction while accelerating but will hinder your braking 60 to 0 kmh time (good ol inertia)
Do not use weights in the back. If you do end up going sideways it is more weight to control and it can always move around in the back making the car extremely unstable.
Just get really good winter tires(do some research). You’ll be fine.
S13s are weighted very well and winter tires are all that is needed to be honest …
bricks??..lol ever here of sand bags(use 1 or 2 at most)…get some studded tires as they are the bes!t i had uniroyal tiger paws, then got studs put in…they were killer on my 180sx!
hahaha those studs were sparking and flying out most of the time
i agree with this 100%, factory VLSD is good too.
does your car have abs? i wouldn’t recommend driving it if it doesn’t. . .
pffff, Every vehicle I have ever driven in winter (except my tempo) was RWD and had no ABS. Good tires and threshold braking and your set.
sand bag it lol :anal
ABS is actually worse in winter. Locking the wheels up creates a pile of snow in front of the tires and helps the car stop faster (leaving you no directional control, but that’s another matter entirely! :)) due to additional friction. I know it sounds stupid, but it’s real car physics and can be easily searched for.
Sandbags are totally the way to go. They shouldn’t move around at all once placed in the back of the car.
ABS is worse…Man i am learning new things everyday. Physics will tell you that there is a greater coefficient of friction when two surfaces have stationary contact with each other. The coefficient is reduced once the surfaces are sliding against each other.
I beleive physics…Not some random Snow Piling explanation.
I prefer no ABS, you have more control over the braking.
just toss a KA24 long block in the back. That should do it. I hear if you go up and down the alleys in edmonton you can find them chillin out.
You know, I didn’t feel like hunting down the explanation, but I should have known that I would have to. Now, let’s triangulate my statement with multiple references, shall we?
If you’ve got anti-lock brakes (ABS), remember that in icy conditions they require slightly more distance to stop. ABS doesn’t make you stop any quicker, just more safely, because locking up the wheels means a loss of steering control.
http://www.canadiandriver.com/winter/wintertips.htm
On the other hand, stopping distances will be longer on snow or ice than they would be using a traditional braking system. The moral of the story : do not overestimate the power of an ABS system…
http://www.mtq.gouv.qc.ca/en/securite/hiver/conseils.asp
Using four wheel lock up
the driver loses full control of the vehicle, increasing the chances of spinning out; however, it results in the shortest stopping distance* in snow and slush (because of the snow plow effect).
- Note that this is not true on glare ice because a sliding tire melts the ice forming a boundary layer of water on the ice, which results in a reduction of the available friction.
http://www.carsp.ca/winter2.htm
And finally, the piece de resistance:
4) Transport FUCKING Canada
Is the stopping distance shorter with ABS?
No! From early commercials, it may have looked like you could stop on a dime. That instantaneous stop is not realistic. When braking on dry or wet roads your stopping distance will be about the same as with conventional brakes.
You should allow for a longer stopping distance with ABS than for conventional brakes when driving on gravel, slush, and snow. This is because the rotating tire will stay on top of this low traction road surface covering, and effectively “float” on this boundary layer.
A non ABS braked vehicle can lock its tires and create a snow plow effect in front of the tires which helps slow the vehicle. These locked tires can often find more traction below this boundary layer.
http://www.mucda.mb.ca/aboutabs.htm
Remember, I never mentioned ice - just snow.
I was unable to find the reference to the snow plow effect that I originally heard from automotive journalist Jim Kenzie, who I respect, but he also wrote an entire article about the myths of ABS brakes.
I like all your examples…But science doesnt lie. Any experienced driver should be able to replicate ABS or even be better than ABS…Its all about threshhold breaking (What ABS does) Never try to tell me that locking up your brakes is the fastest way to stop.
We learned about the snowplow effect in snow in school when we learned our abs module. Basically the question is: Do you know how to drive in your car in winter? and always no your limitations.
