Got a good deal on a Motorola wireless router so the wife can use her laptop where she wants.
Finally figured out it wouldn’t connect because the signal was too weak from the basement (where the cable modem is). :mad: So I hooked up the old hard wired router in the basement, then hooked the wireless router to one of the lines upstairs. I assume that’s okay to do?
I now get a strong signal (54 Mbps) on the desktop since the router is right next to it. Her laptop in the kitchen is a low signal (11 Mbps).
Is that normal for only being about 20 yards away with just a few drywall walls between?
Does the low signal speed have any significant effect on anything?
Should I setup a password to connect to the network or is it secure how it is?
Remember that wireless has to send/receive the same signal strength, so if your notebook has a crappy receiver then you are at the weakest link which might not be your wireless AP.
I didn’t see what IEEE standard the router and the card are. If your router is 802.11G and your card is 802.11B then it will work but your cut down to 11mbps right off the bat…Like I can go down 3 floors and across to the other corner of the house and still have a faster connection than 11mbps, but again thats using both wirless G nodes.
Make sure the firmware is up to date on your router and you should use WPA at the least. Your wife will have to run WinXP SP2 though for WPA accessibility. Then you can enable SSID broadcast as well again to make it easy to configure.
yeah… i only said wep so that he could have the lowest level of security… i mean, if he can’t even get signal in his kitchen, i don’t think haxkzor2 are outside waiting to compromise his files :kekegay:
