WTB: DOHC power steering lines (Hicas)
For a 1993 DOHC w/ Hicas…
The ones from the front of the passenger frame, that run to around the rear passenger wheel or so. They run along the passenger frame rail.
If you have the brake lines that run that way as well, let me know.
Cheers.
your better off going to a powersteeringshop and getting them replaced
it will be cheaper and they will be in better shape
it is also very easy to take out hicas, you can do that if your hicas lines are leaking
