WTB: Fuel Pump KA24DE or 300ZX Fuel Pump
Looking to buy a fuel pump for a ka24de but I will consider a higher flow pump as well as i’m going to an sr20det in the future.
:? You could find a high flow walbro fuel pump on eBay. Doesn’t look that they’re too pricy on the site.
I have one from my 240. Used, $50.
If you buy a walbro, try the 190lph. Everybody else has tried the 255 and I believe the 190 is more than enough.
Yeah but if he is going to put one in might as well use the better one.
I’m recommending the 190lph high pressure. I don’t consider bigger is better in this case. For the long term health of his regulator. After running a 255lph for 2 years, this is my recommendation.
with further upgrades I would say go with the 255lph if your not going to do much more try out the 190lph. If you do decide on the 255 I’d suggest an afpr.
You should be able to pick one up for ~$150 brand new from a shop here in town. I wouldn’t bother using Ebay for this thing. If it fails, you’re fucked.
