I’m replacing my dads brakes on his altima and I can’t for the life of me figure out how to get the rear rotors off. I got the caliper off and out of the way but can’t figure out if there is anything else holding the rotor on.
some people accidently leave the e-brake on, only other thing I do with stuck rotors is heat + sledge hammer
I ended up using a bolt and nut threw one of the holes that holds the caliper to the hub. Used that to put outward pressure on the Rotor and they popped off. I did use heat on the other side with the same bolt and nut technique and it seemed to work even better.
Thanks
BFH…
yes the bolt technique is another good way…actually its what those 2 holes are for
