Follow these instructions to wire in your sensors. (30-1600/1601/1602/1603/1610/1611/1612/1622)
MAP Sensor
There are 3 wires on a MAP sensor. It requires MAP signal, 5V reference, and sensor ground. If you’re using an AEM MAP sensor: MAP signal is green or white, 5V reference is red, and sensor ground is black. The signal wire needs to be dedicated, meaning that should be the only wire making contact with that pin. The sensor ground and 5V reference wire can be tapped. Please follow the pin out below to wire in your MAP sensor. If you did everything correctly, with an AEM 3.5 bar MAP sensor, your MAP voltage (setup/sensors/map sensor parameters) should be about 1.6V with the key on engine off, with an AEM 5 bar MAP sensor, your MAP voltage should be about 1.3V with the key on engine off. Remember to select the correct sensor in your MAP sensor wizard.
MAP signal - Pin 35
Sensor ground - Pin: 21 and 29 (tap to one of these)
5V Reference - Pin 37 (tap to this pin)
30-1610/1611/1612
MAP signal - Pin 66
Sensor ground - Pin 50 (tap to this pin)
5V Reference - Pin 49 (tap to this pin)
30-1622
MAP signal - Pin 35
Sensor ground - Pin 30 (tap to this pin)
5V Reference - Pin 48 (tap to this pin)
Air Intake Temp. Sensor
There are 2 wires on a AIT sensor. Polarity does not matter. It requires AIT signal and sensor ground. Please follow the pin out below to wire in your AIT sensor. Remember to select the correct sensor in you AIT sensor wizard.
AIT signal - Pin 26
30-1610
AIT signal - Pin 63
30-1611/1612
AIT signal - Pin 28
30-1622
AIT signal - Pin 36
Boost Solenoid
There are 2 wires on a boost solenoid. Polarity does not matter. It requires switched 12V and PW2 on EMS. Please follow the pin out below to wire in your boost solenoid.
30-1600/1601/1603
PW2 - Pin 111
30-1602
PW2 - Pin 102
30-1610/1611/1612
PW2 - Pin 34
30-1622
PW2 - Pin 25
Wideband (this is for EMS without built in wideband)
If you’re using 30-4100 (Gauge type wideband controller), 30-2300/2301 (Dual/Single channel wideband controller), or other wideband controller with a 0-5V output, you will need to tap the 0-5V output wire to the O2#1 or O2#2pin on your EMS. White wire on 30-4100, and orange wire on the 30-2300/2301. Please follow the pin out below to wire in your wideband.
O2#1 - Pin 19
30-1610/1611/1612
O2#1 - Pin 46
30-1622
O2#1 - Pin 29
O2#2 - Pin 55
Please reference our Instructions page for any EMS pin out or other instructions http://forum.aempower.com/forum/index.php?board=90.0
If you have AEMPro installed on your computer, the instructions and pin out can be found here: C:\Program Files\AEM\AEMPro\Instructions
