My first car and my second wife. I’ve had her since 2006 and I’ve always gone the opposite direction in my build than the average 240 builder. Never went for the slammed drifter/park look or cheap china parts.
While everyone wanted to drift I wanted to corner fast and go fast. I entirely focused my entire build on grip and cornering rather than looks or all out power.
This car has been totally unorthodox but I’ve put a lot of thought in the build. I was going to tube it front to back but someone that was going to do that work screwed me over and it’s been rarely driven since, not raced and sitting in storage.
It’s time to let her go… I’m second thinking myself but I have no time to continue this project which was to be a dedicated time attack car… I just want to get into a clean/stock smartly modded FD RX7 for occasional track days.
This would be an excellent project for someone who wants to continue where I left off to build a seriously competitive package for the track. A V8 power plant, tubing the car front to back and caging the chassis is what I was going to do next. I also have an uninstalled BN Blister bodykit (front to back) and 72" Kognition race wing (that are not included).
Engine/Drive train
-Stock KA24DE with chain guides removed
-Emission components removed
-Z32 Fuel Filter
-NGK Iridium IX BKR6EIX-11 4 Spark Plugs
-DC Sports 4-2-1 Header (2.5" exit)
-BRM 2.5" Full catback with dual exit tips and 22” resonator
-Bings polyurethane exhaust hangers
-2.5" Testpipe
-3" Intake
-Triple core Griffin Racing radiator (great for V8 and racing duty)
-NISMO thermostat
-Aftermarket Ignition Coil
-12mm spark plug wires
-Cusco engine mounts
-Peak Performance S13 Pro Race Polyurethane Tranny Mount
-Megan racing short shifter
-Cusco bottom shifter metal bushing
-1lbs weighted shift knob
-Stage 3 Cerametallic puck clutch
-10lbs chromoly flywheel
-10lbs aluminum driveshaft
-Braille Carbon fiber 10lbs battery
-Brand new fuel tank, brand new fuel straps, installed in tank 255lph walbro fuel pump
-New metal fuel lines coated red (stock were rusted had to be replaced)
Suspension/Brakes
-Front and rear custom coilovers:
Koni 8611 DA race shocks front and rear
Eibach Race Springs 600# front and 450# rear
Front Ground Control Camber and Caster adjustable pillowball tophats
Rear Tein pillowball tophats
-Front and rear Ichiba 5 lug hubs/bearings
-300ZX master brake cylinder 1 1/16
-Stainless brakelines
-New metal brakelines (stock were rusted when I first got the car)
-Front Wilwood Billet 6-piston Aluminum calipers with 13" (332mm) x 1.38"(35mm) thick 2 piece rotors
-Rear Wilwood Billet 4-piston Aluminum calipers with 12.2" (310mm) x 21mm thick 2 piece rotors
-Rear Brake Bias valve on transmission tunnel
-Enkei RPF1 17x9.5+15 SBC wheels front to back with 255/40/17 Nitto NT01 R comps
-Tanabe tubular front swaybar
-Custom Heim Jointed front endlinks
-Brand new FLCAs
-SPL Outter Tie Rod V5
-Tein Z33 Inner Tie rods
-Yanack Steering Rack Aluminum Bushings
-FRSport Steering Column Aluminum Bushing
-NISMO front subframe brace
-Rare JDM Traction Rod to front subframe brace (Yashio Factory Core Support Guard KIWAMI)
-Clean/Rust free S13 Sub frame with SPL solid bushings
-S15 Helical LSD and output driveshafts
-Z32 upright with Defsport heim jointed bushings
-SPL Rear Upper Control Arms V4
-SPL Traction Arms V4
-SPL Toe Arms V4
Chassis/Exterior/Interior
-Evo 2 Plus driver seat with Bride low brackets/sliders
-S14 JDM passenger seat
-TC Sportline F1 style mirrors
-GT-Spec C-pillar brace
-GT-Spec S15 R Spec style Trunk Brace
-DC Sports Front Strut Tower Braces
-DC Sports Rear Strut Tower Braces
-330mm Personal Neo Grinta 330mm black leather-read stitching steering wheel with working red horn button
-NRG slim hub and NRG quick release (both aluminum anodized)
-TC 70mm extended steering wheel spacer (aluminum anodized)
-Stripped interior (heating, air, speakers/audio, all related wiring minimized)
-Custom cut up and lightened stock dash for easy instant removal
-All internal panels and sound deadening removed
I think this is all, if I remember what else may be on the car but this is what I can recall right now.
-No more popups (kinda bad or unique style lol):
It’s half assed but one headlight comes with a functional HID low beam and regular hi beam (half assed long story) – the HID are hella projectors and they are money.
Other is an EastBear hi/low non-popup headlight installed (very rare – I have both but only one installed cost me 700$ used it’s out of production)
The story behind this sloppy headlight work is one summer I had no car and I was in the middle of cutting away the rad support to do the custom headlights and didn’t get to finish… needed a car… Never finished it. Got the EastBears (rare) but didn’t want to remove the HID half assed one.
THE BAD:
-Needs IACV it can’t idle all the time, but when it runs it runs great
-Exhaust leaking some place as you can smell the fumes in cabin
-Needs front frame rebuilt
-Outer panels are shit (plan was to cut everything away and install replacement fiberglass panels anyway)
-Front wind-shield has a crack
-Tires are ice skates/heat cycled to death/old and need replacing
This would be an excellent project car for someone with the skill and shop wanting to build an unorthodox time attack car.
I am willing to trade for a stock/unmolested/lightly modded FD RX7
or
11,000CAD
- Updated - - -
Old video before further gutting, before mirror removal, before popup headlight replacement and before a few other mods:
- Updated - - -
Despite being a KA, I could give a run for the money to modded WRXs, S2000s, and SR 240s at cayuga. Great corner, response, later braking, etc…
The boltons on the KA and the clutch/flywheel/driveshaft, etc… made for quite a response NA car. A V8, chassis/cage work and fibreglass panels would complete the car.
- Updated - - -
Pics before F1 style mirrors and headlight removal:
[ATTACH=CONFIG]32180[/ATTACH]
[ATTACH=CONFIG]32181[/ATTACH]
[ATTACH=CONFIG]32182[/ATTACH]
[ATTACH=CONFIG]32183[/ATTACH]
[ATTACH=CONFIG]32184[/ATTACH]
