ok so i drained the fluid and put in some new stuff. i read the book and thought it said 3 quarts, and put 3 in. it took all 3 quarts but later i re-read it and it said 2. how bad is this? is it bad at all?
where i poured the fluid is right under the shifter, clutch cables on the tranny.
i dont know the specifics of your tranny…but if you know what you did is wrong…find out how to properly do it, or find someone who can, and do it again. 2 quarts of tranny fluid isnt worth any headaches that may surface from fuckin up the job
well if you have been driving you know theres fluid in there…if there was no fluid in your tranny you would def know it…other than what you read…is there any other cause for concern? how does the tranny shift? or have you not even touched it since
ok, i got more fluid to fill with but how do i remove the fluid i put in? i have no idea where that fluid is sitting or if its gonna damage something in where i put it. thats what im really worried about.
just look at the picture that Gary (devioustsi) posted on wnydsm. You want to unscrew the drain plug at the bottom of the tranny. It’s a 19mm bolt. Just unscrew it and let the fluid drain out, put it back in and tighten it and get yourself a funnel with a hose on it and fill it the right way (in the fill hole). About 3-4 inches above the drain hole on the “side” of the transmisson.
Maybe it ended up in the correct spot. If you remove the fill plug or drain plug and fluid starts coming out you should be set. Just make sure you remove the fill plug and let all of the extra fluid out
Worst case scenario is that you put fluid through the bell housing vents…lol…that would suck
I have no idea, I’d have to look at it. I have to imagine it’s in the transmission. There may be a screw/plug that is on top that enters to the inside.
If we’re saying it’s in the transmission then, no it wouldn’t be coming out somewhere because you don’t fill the whole case of the transmission with fluid, just enough to coat the gears. Therefore you have too much in there but not enough to be completely full.
I hope not since you’ll be taking out your transmission to change your clutch. But I don’t think you did because I think it would be leaking between your transmission and the block. Since you havent’ mentioned it, you may be fine.
Just go out there and unscrew your fill plug and see if the fluid comes out.
