Hey guys can I ask if it is possible to replace my current cranking windows into power windows? Do I have to replace the door or… Not very sure what exactly is needed. Thanks!
you need the window regulator- which includes the motor and track that slides the window up and down.
find the door with the power windows, and transfer everything over, even the trim panel.
the electrical switch you’ll need rewire it
there is also aftermarket retro-fit kits you could buy; but both changing everything or adding the kits is sadly not worth it (unless you have a good amount of time).
Cheers
dont dooo it lol my regulator went on my car lol. sooo the power window on the driver side doesnt work. lol
i have doors for sale to fit your needs or anyone else’s. Now you might need the wiring from the door to some sort of module. i also have that. Send me a pm if your still interested.
haha i have been planning on the same thing, just swap out window fames and such and you should be good, you would want the power door locks to, so you can ither go with the door lock timer rough in or aftermarket. level 12 would be able to help with both if youd like i belive.
care for it regular , so that you can overcome the problems like it
