ok so i got the new TT fuel pump…hook it up, but car still wont start. we notice the pump doesnt hum or prime itself at all when turning key into on position so we assume it’s not getting power…check for power, and nothing anywhere…then we notice none of the dash lights are on with the key in the on position…and the relay box isn’t making any clicking noise when turning the key on like it should…we try to check for codes…and the ECU has no power going to it. car will turn over but not fire up, all other accessory shit works, but anything controlled by the ecu…spark, fuel pump, etc are not getting any power. we bypass the fuse and get the pump to work so we at least know it’s not bad…some relief i guess…
we call my wrench that did the swap for me, he said check the security system…i didn’t know i had this, but behind the board/interior body panel that is like in front of the driver’s knees…right under the steering wheel…there’s a little black box with a switch that i guess is the main power switch for this gay security system…and i also guess that if this security system is tripped or set off, it causes the car to go into some safety mode where it will not provide power to the ECU, not allowing it to run, i guess to keep it from getting stolen or something…
we reset that by just like playing with the switch a few times, and the car fired right up…drove it a bit, was fine…parked it…turned it off, then it turned right back on when i tried…
i turned it back off assuming all was well, but just to be on the safe side decided to let it sit for a bit before trying to start a third time…and after about 10 or 15 minutes, it wouldnt start again…same shit as before. no pump priming noise, no lights on the dash other than the obviously flashing “security” orange light.
i tried to turn it on, nothing…radio came on, pissed me off because i didn’t wanna hear it, and as soon as i hit the off buttom on the radio, the dash lights came on, and i was able to start the car…turned it off again, and then it wouldnt turn back on…just kept turning without firing…so we aren’t sure how the security system is connected with the radio, how that would have caused the car to start…but we are totally confused…
what i’m asking you people is if you have any idea what could be causing this strange electrical problem…we checked all relays, all fuses, all wiring…everything else seems to be good…
and if it is my gay security system that is causing all these problems, and if it is somehow tied in with the radio, is there any way i can just totally bypass or override or just get rid of this do-nothing-but-cause-problems security system? i really dont need or want it at all, i’ll save up and get a good security system soon enough…
i also noticed that we hooked up the light in the boost guage to my headlight switch…but i noticed the wires from the light on the guage go into this little black box that has the switch for the security system in it…is this box for all of the interior electrical accessories? because if it is, that would explain why messing with the radio might have had some effect on the car starting that one time…
thanks again for the help guys…
