ran a turbo KA24e racing for 6 years…and it was very fast , ran 24psi boost on race fuel out put was over 400whp 450ftlbs …however the thermal issues and high duty cycle sucked for road racing…
so…there is no replacement for displacement… as they say…
bought a LS1, had it rebuilt, hinson headers, did a custom front crosmember, and driveshaft, Kazz 1.5 rear end, and speartech ECU/harness. Bam…one winter later it was up and running…
ran a straight 3 inch exhaust no cats out of the headers…
used my 2 core turbo rad to keep the heat under control…added 275 front tires and 315 rear tires to keep the power to the ground…
bone stock 1998 Ls1 does low 12’s
---------- Post added at 05:55 PM ---------- Previous post was at 05:46 PM ----------
this year I just picked up the parts to turn it into a LS6…basically adding at least another 80hp to the engine… new cam, heads, and intake manifold. So It should dyno in the 380-430rwhp range…and if I were to drag race maybe high 11’s
biggest issues so far have been shearing hubs from the torque…and later in teh seaon shered through a diff…lucky my Kazz 1.5 did not get hurt…
basically dont drag race these cars with stock rear ends and hubs… the grip of the 315 R tires is too much
only odd thing on the build up was that I had to convert the retun fuel system into a returnless fuel system due to the LS1 engine…
---------- Post added at 06:02 PM ---------- Previous post was at 05:55 PM ----------
car does 1:31’s with the Ls1 engine at mosport with me driving (lots of time left on the table)
it does 1:18’s at calabogie only been there once so I am sure I could knock off a few seconds more easy once I learn the track
---------- Post added at 06:14 PM ---------- Previous post was at 06:02 PM ----------
ohh… tranny is a T-56 6 speed out of a viper/mustang/camero…so far been a great tarnny…no issues
with the rear diff gearing gives it a top speed of 190mph(304kph) in 6th… fastest I have had it up to is 253kph on the back straight of Mosport…and it still had lots of legs left
for comparison slightly modded Ka24e does 171kph on the back straight
