interesting race
3xxwtq vs 18xxwtq
Both cars are quite impressive…but 1800lbs. of torque??? Goddamn!!!
Twin turbo Dodge diesel?
Aren’t they Inline 6’s?Does it matter?
cummins are I6’s. they are tq monters. the newer ones only have 1 cam bearing believe it or not. little factoid
inline 6…and they use compound turbos…
Basically one turbo feeds the other… I’m guessing that dodge was running upwards of 100psi.
Compound Turbo Charging (One turbo compressor wheel feeding the other) is not the same as twin turbo charging. A compound turbo utilizes different sized turbos feeding off one another to do the job of one turbo. Air enters the low-pressure turbo (the larger of the two) and is fed into the high-pressure turbo (the smaller of the two), then directed into the engine or intercooler. This is why this type of turbo charger arrangement is referred to as Compound Turbo System. Compound Turbo Chargers work in series.
its also called sequential turbocharging :smash2:
I would still rather have the Dodge than the Honda.
Yes, I know, But it sounded like you were trying to correct me… if you woulda said that ^^ in the first place then it would be fine.
dam… thats a badass truck… lol
that dodge would’ve had a chance if it had vtec.
:massmoon:
I’d pull trailers full of concrete/a car on it with the dodge and bet people that I could run 12’s
