I just bought a 95 neon 5 spd yesterday. The guy lied and said he changed all the fluids, meanwhile there is no tranny fluid in it at all. Infact when i went to put tranny fluid in it today, it all leaked out in the drain, which i found out had no plugs in it. Where could i find the plugs for the tranny so the fluid doesnt leak out. Also, the tranny sounds absolutely horrible when driven and when the clutch is let out, does anyone know whether its the throw out bearing or just needs fluid?? Any opinions would be greatly appreciated!! Thanks AJ :burnout:
Sounds like both!
well i tore everything apart today and there was a hole right near the plug to put the tranny fluid in. Got some jb weld, hopefully it holds once its set and i can put some fluid in it
