99 integra help
my friend has a 99 integra ls recently replaced clutch and flywheel and sometimes when driving it the clutch peddle will stick to the floor and he has to try and pull it up with his foot
we then replaced the slaver cylinder still dose it then did the master cylinder still has the problem anyone have any ideas
stupid question but did you bleed the lines?
yes all 3 times when we did the clutch and both other parts i was thinking a faulty pressure plate
Maybe…but it sounds an awful lot like an air bubble in the lines.
Theres definetly air in the line.
check for leaks
