u can swap it in, it just pushes the driveshaft towards the tranny a bit, its better to get an abs driveshaft to prevent tranny seal and driveshaft suspension bearing from wearing too quick, mine is like that, nothing ever happened
fack!..so it should be fine if i just swap it in like that?..how much are we talking here…mm-cm-inches?..how much wear or strain is this gonna put on the tranny.
streching the distance is different cuz ur not putting presure against the tranny, however pushing it till its 100% tight with no shaft play or nething is the scary part.
i got it in with no problems… just a lil tight to go on but it fits almost flawless.
