can u use the ac fan as an electric fan on a 240sx?
i guess the question is…will it keep the car cool or does it not spin fast enough?
Mine works pretty good. The car’s only almost overheated once, and that was in a traffic jam in Montreal in the middle of August.
I just grounded out the fan relay to come on in acc mode.
are u using a stock shroud?
i have allready modified my stock shroud to fit the fan
do u mean as soon as u hit ac on the dash the fan comes on? theres no ac in my car anymore everything is gone?
is there another way? like can i ground it then put a relay switch in the cabin?
Yep, stock shroud.
No, the a/c fan relay is on a temperature switch. I just ground the relay out, so when any power is given to it, it activates. So it’s on whenever the car is on or in ACC mode.
nice i might do that, is this for KA or SR ? I was thinking of buying a electonic temp sensor from CT and hooking it up through that, what do you think…
its for ka…for sr get dual altima fans i doubt the ac fan is good enough…sr’s are turbo they need more cooling
I run a stock KA rad and a stock KA ac fan on my SR and I’ve never once had an “over heating issue” not even in traffic jams…
My fan runs 24/7 as long as the car is running
Something you may want to consider also is on JDM 180s/Silvia’s etc they have TWO elrectic fans (one infront of the rad, and one behind it) so one is sucking in air while the other is sucking it out…
I myself will be placing a smaller electric fan infront of my rad just for the hell of it…
on the ac fan…theres two wires going into it, is one positive and one negative?
if so im just going to run a relay switch to the cockpit, i dont trust all my ac stuff
yes one would be positive and the other would be negative…
