Almost finished my ehxuast
Here are some pics of the final product, just have to polish a few thigns here and there. Full stainless steel, looks really good on the car, although I’m very tired of putting it on and taking it off so many times.
Took me about 10 hours total, including correcting the improper mounting position 4 times (cutting/rewelding). Need to put in another solid hour of work and this thing will be a beauty.
It’s a 3" exhaust, split into twin 2.5" pipes. The ugly middle hanger will be ground down and made nice… I just ran out of metal for hangers. :oops:
Because those who have seen started asking me question my answer ahead of time is NO I WILL NOT make custom exhausts for people, my time is too valuable and you cannot afford it, so don’t even ask.
Here are pics:
http://img162.echo.cx/img162/3350/s42000054xy.jpg
http://img162.echo.cx/img162/3804/s42000062hh.jpg
http://img162.echo.cx/img162/8024/s42000071vg.jpg
GANGSTA!!!
now put it on the car, move it out of the garage and TAKE MORE PICS…
i think u shoudl angle cut the tips a little bit
pavel man, your cars gona be hot as shit this year, same with derek and andrew
this is gona be a fuckin fun summer!
upon further inspection… no resonators… all straight through…
this is going to be friggin loud as hell
I think you’ll be surprised.
yeah bing, my car only has one BIG ASS muffler and my car isnt TOO loud
might be a bit raspy like the team orange car with the trust dd but im sure its gona sound great
looks amazing Pavel! good work.
A little dissapointed, was hoping to see something more different, and a little bit over the top. :frowning:
hey u gotta give props for the cost and DIY factor.
i couldnt have done it, thats for sure.
of course it isnt perfect, and Pavel knows that, but if it works then he will have the satisfaction of knowing he built it and shaved $500 of his cost of swap.
plus DD style is NUTZORS…
if i had to get another exhuast it would be the only one i would consider.
given what you had to work with good going.
I’m worried that the ‘T’ you have for the 2nd pipe may be taking from over all flow, if you can try to ease in the 2nd tube as say a 20-40 degree angle…
a quick fix might be to just chop a round out of the 2nd tube and the main pipe and then fab over a pc of sheet metal… so it tents over the hole… just a thought.
is that rebar you used for a hanger :lol:
Looks good, can’t wait to see it mounted.
Oh btw, WILL YOU make custom exhausts for people?
Looking sweet Pavel.
As mentioned my only concern would be the area where the pipe splits.
It looks like the one on the right won’t be getting much flow into it. If you
have time talk to me on MSN… I have an idea on how to do that with the
materials you already have and make it perfect. (If you even care that is)
Overall good job…
(Pavel first touched a welder a month ago, now hes on a rampage :slight_smile: )
I’ve seen the exhaust and it pretty tidy for a first try at an exhaust. When he actually fires it up I’ll be the first to buy him earplugs :smiley:
What’s with the bend at the Y-section?
And why hasn’t anyone created a cheater/dump pipe? :dunno:
The flow in the split will be good because the pipe coming from the side actually laps inside of the 3 inch so it takes a lot of the flow from the 3" pipe.
Also. if you calculate the surface area of the 3" pipe is 1.5^2 x 3.14 = 7.065
The 2.5 is 1.25^2 x 3.14 x 2 = 9.8125. Using the formula of pi x radius squared. I still have room to spare, so i think it’ll be okay, thanks for the concerns though.
Applesauce, my car is a street car, I’d love to make my exhaust come out through the front fender, or before the rear wheel or on top of my rear wheel, but that will just attract even more unwanted police attention, sorry to disappoint you.
Homebrew is always awesome no matter what.
I was looking forward to a side exit with sepperate pipe for the waste gate. Not to worry, I’m sure this will be a heat score without a muffler or resonator. :slight_smile:
just go baller pavel and get the apexi ecv. and use it when necessary…
why so many bends? and why 2 exhaust tubes 1/2 way thru?
when i made mine out of 3 inch i was able to almost get it straight? with only 2 bends 1 for the down pipe and one for the rear cannister
http://www.turbo240sx.ca/3inchexhaust.jpg
http://www.turbo240sx.ca/3inchexhaust1.jpg
other than that looks like alot of time and work put into it…so kudos for that…
Cause pavel is a silly drifter! hahaha
AMAZING DUDE!@!!!
now all it needs is slash cut tips!! cut them both at a downwards angle man it looks so sex
http://www.driftday.com/dd_alone_T.jpg
