hey ive got some konig monsoons and gonna be puttin on 255’s in the back, just woundering if it will clear or will i haveta roll the fender. car is lowered. if i do haveta roll the fender anyone know how or have the tool to do it. thanks plz come again
You can fit more than a 255 in the rear. LOL I’ve seen 275’s under there.
This is a 255/40-17 on a 17x9 +38 wheel (on the rear). No fender mods either.
nice thanks for imput, also anyone know the size of the single big nut holding the drive shaft in? on the rears one on both sides, and a cotter pin in front of the nut.
Do you mean the rear axles?
yes…i mean the nut holding the rear axles
should be a 32mm
36 on rears
tire size is not the biggest problem when trying to fit a tire/wheel combo as it is usually rim offset. If you were trying to fit a 17x9j rim and a 255/40R17 tire it would probably rub on your suspension or hicas or ect.
What offset and width are these rims… that would be more of a deciding factor on a S13 as you can fit alot bigger tires than 255 on the rear with stock fenders it is jsut you would have to play around with offsets.
