After reading the rental car review, and returning from a weekend of riding in PA. I figured I’d post up my thoughts. Feel free to add. I’ll be adding to this as I have time.
Oh, and I know…
2006 polaris sportsman 500 EFI -
I rode this most off the weekend. To me this was underpowered. clutch comes on slow, but on the other hand I put 100 miles on this and I felt like I was on a couch. Very comfortable to ride 25-35 MPH. This is for someone with back / neck probelms or a girl that has no idea how to ride. Rolls into corners, took a ton off effort to get it to slide. The 4 wheel drive was meh. it works like a traction control system. take power from one wheel to the other so when your climbing a step hill it fights you side to side. On the flip side the EBS (engine braking system ) works great. cover the brakes and let it work. Steep hills you have to blip the throttle a bit to get it to catch again.
Over all comfortable ride, slighty underpowered, EFI starts every time no choke BS.
2007 Grizzly 700.
This is my moms wheeler. This thing is a beast. The ride much stiffer but the IRS works well still. No power issues here. This is easier to slide but still takes work, if you corner to quickly it still gives for the novice riders. EBS on this, not so great. The brakes on the handle bar are front / rear as the polaris is all 4 in one handle. Takes some getting used to for braking down hills. On the flip side this thing going up hills is great. No heed to use low hit the 4 wheel button and get some, or lock the front diff in and crawl in low. I’ve towed haywagons full with the 660’s this is set up to work and play. I wouldn’t reccomned this for inexperienced riders. Heavy, powerful toy you could get yourself in trouble with.
2011 polaris razor -
This is my favorite. The only way I can discribe this is like a trophy truck. Very powerful yet very easy to manage. Has a little understeer that needs a little getting used to. It will fit in the bed of a pick up. It had no problem going anyplace the wheelers did. The only down fall is the lack of fenders once you hit mud your covered.
2009 Yamaha Rihno
Not bad. Stiffer ride. Plenty of power. Again more of a work and cruise around machine than a full out off road toy. I would still buy one to use for work around the farm and ride trails with. Decent fender coverage and still a comfortable ride. Won’t fit in a truck box though, won’t clear the fender humps.
2007 Raptor 700 -
Plenty of power, fun, fast trail wheeler. I wouldn’t take this to the moto x track but its deff fun to rip around on. EFI and reverse is a huge plus.
2003 polaris predator - This was to me the best sport trail ATV. Had a little bigger tires on the rear and has more ground clearance than YFZ,LTR ect. I’ve been finding these cheap used. I have yet to ride an IRS. No reverse.
2006? LTR 450 -
I would buy this and take it to the track. snappy sporty low. Then faster you hit bumps the better it likes it. Not trail friendly, just hung up easy and has no reverse.
