Can’t stress this enough …
You really can’t put an average price on it.
Every motor seems to come in varying conditions. Not only do you have to factor in all the added costs of extras (upgrades or even OEM replacements) then understand that your engine is coming from someone other than the mechanic, so if the motor needs work, you still have to pay the mechanic to do it, whether or not the importer warranties the parts.
If you come to the swap with all the parts needed, (ie, I/C piping, exhaust) and they are bolt-on, not bolt-on with some mods, or full custom, the full harness is there (AND INTACT …), MAF is there, the clutch is fine (or you have a replacement) the flywheel is good, the swap is going in to the same generation chassis, and the chassis it’s going in to isn’t a rotten piece of crap, doesn’t include auto to manual swap …
You can probably find someone to do it for $2gs.
Although you’re going to find a lot of shops unwilling to do JDM motor swaps any more. It’s too frustrating to try and explain the process to owners who come in with a degree in Googlogy, some bad 3rd hand information and a limited budget.
It’s almost impossible for a shop to make money on these swaps. Then you have to deal with this customer for the next while every time something goes wrong.
We’re at the point we’re turning work away. Other shops are fed up with hand-holding and babysitting cheap owners who expect a $50 junkyard motor to run and act like a brand new 0 mile top fuel drag motor. So they’re trying to outsource the work to us.
They don’t feel like tying up a bay that can churn out 5 or 6 $100 jobs in a work day for a car that eventually is going to work out to $100 a day.
When these motors fail, owners don’t like to find out a) the shady guy they bought the motor off of won’t warranty it, or b) that even if the guy warranties the motor, you still have to pay the mechanic to remove it, and put it back in again. Then you’re playing Russian Roulette with another motor.
With RBs or anything that requires custom work, you’re at the mercy of the shop. I’ve heard of enough people dumb enough to agree to hourly work for a custom engine swap, only to find out that at $85-100/hour a months worth of work adds up really fast.
Sure there’s guys that will do straight swaps for less. But when you agree to a $500 swap, that’s going to be a driveway, no warranty, no liability, straight swap – what the motor comes with, goes in.
What you save there, you’ll be paying out when the motor has to come out again for a clutch swap, when the pigtailed and electrical taped wiring falls apart or gets wet, fuel pump when it burns out.
God forbid you get electrical gremlins. Call Nissan and ask them what they charge for wiring inspection and diagnosis on a swapped motor. If they’ll even agree to it, that $2-3Gs to get it done right in the first place will start to seem like a pretty good deal. Especially considering it’ll probably be a 20-year old tech with a fax from Japan scratching his head raping you by the hour to figure out what’s wrong.
Simply swapping a motor for another one is a lot cheaper though. Like a KA-KA or SR to SR.
