I have a parasitic battery drain - I’ve looked around on the net & forums looking for typical resistance (ohm) values for nissan 240sx at the battery terminals (with battery unplugged obviously). I am losing 0.5 volts overnight. Alternator is good - quest putting out 14.1-14.4 volts constant, battery was replaced under warranty 2 days ago and still same issue. FSM doesn’t have what I am looking for.
It’s a 95 base model. When car is OFF (no accessories, no engine running, etc.) I am getting around 0.8 kOhms between positive & ground battery terminals so that tells me there’s a decent size short somewhere. I realize other factors such as constant power drains - remote starters, etc. can affect it so I am looking for someone with an electrically reliable working 240 to compare the resistance values.
Could anyone who has left their car for a week & still started it without removing the terminals please chime in
310 mAh drain so roughly 12v x 0.31 amps = 3.72 watts per hour drain… I’ll trace it by disconnecting fuses & measuring drain to see when it disappears. For now negative clamp off until I drive
^ That’s how a shop would start a basic diagnosis, connect the test light between the battery and the terminal, key off for 1-5 min then start pulling fuses.
Solved. Thanks guys. Tested using ammeter & pulled all accessory fuses - no change. Pulled 7.5 alt fuse and found the issue at the charge alternator connector I replaced a while ago (since old one had torn off). I used the connector from nissan quest which I wired up wrong causing the parasitic drain.
Correct wiring:
s14 alt charge connector quest alt charge connector
white w/red stripe ----- yellow w/stripe
yellow ----- blue
