Ok so i have all new brakes, system is has no air. but the E brake light keeps coming on as if i have low fluid. I played with the float and it seems ok.
The ebrake is fine becasue my alarm realay goes off when i put it down.
Its anoying evey time i let off the gas or hit the brake it will come on and make a buzzing noise.
Any ideas? I had the MC off over the winter and all the wires out of the car.
thanks
justin.
how is your fluid level?
Its good, I don’t get why it comes on and off when I adjust the gas pedle. Must be a wiring problem.
im not 100%, but isent there a Vac line that Go’s off of the Master Cylinder to the Engine?
that much be something to check out if happeneds when you Rev/etc.
Brake light usually means alternator…
Don’t ask why but thats what the FSM say’s and thats what happend to DTS.
