Check the main harness under your driver’s fender well, and follow it across your rad to the other side. There’s a good chance there’s a wear spot on it and some wires are fuxord. Repair the wires and you should be good to go.
There may be other causes, but I’d check this first. I had a spot worn on mine, but it wasn’t in the fender well like many people, it was worn where it goes around the rad.
i got the window fixed and my running lights were out also did not know that but that was only a fuse still can not get the brake lights to go n e one else have an idea
