Excellent, I’ll see if the make those for my car. I want to be able to have fun on mountain roads and eventually autox the car without totally trashing the brakes every time. A track day would be really fun, but I want to get better at driving first, and there’s a few more parts I want to get.
fixed that for you
Also flush your brakes and put in some good fluid (Motul, ATE, etc.).
There’s no better way to get better at driving than doing an HPDE (driver’s school) on a real track. Get a BMWCCA membership, sign up for an event. Don’t waste money buying parts that you think the car needs to handle better or what not. At a track, the only thing you need is safety and brakes. I’ve seen guys on track with some jalopies, such as a newish Ford Five Hundred. I’ll let you think about that for a moment and let it sink in… A Ford… Five Hundred… On track.
As Brett said earlier and Jeff also just said, brake fluid is important as well. For any street car, ATE superblue is perfectly fine and has a high enough wet/dry boiling point. Once you really start using the brakes, which I can promise you will never happen on any mountain road or street, jump to Motul or something more expensive with even higher boiling points.
The parts I was referring to were mainly brakes actually. Rear disc conversion and some better brakes up front (rotor over hub conversion). Only non-braking system part is maybe a rear sway bar (car didn’t come stock with one), mainly to make the car more fun and reduce understeer/cornering on the wing mirrors. That and a couple repair parts/general things a 14 year old car needs.
And the thought of a Ford Five Hundred going around a track is makes the part of my brain that I use in physics classes hurt a lot.
