Brake problem
The brakes on my girlfriends quad (timberwolf 250 4x4) do not release properly once they are pulled. They are cable/drum brakes and I can not figure out what to fix. The cable itself seems to move fine but the lever on the brakes is stiff. Any ideas??
I would start by taking it apart and regreasing the calble. Check everything over good and make sure nothing is out of the normal. Then move to the brakes and do the same.
