Brake Questions.
I’ve been looking around at brakes and such for s13’s. I’m no brake wise thats for sure.
I have stock brakes on the back and for some reason the guy who owned the car before put 5 lug and z32 brakes on the front… so 5 lug = front, 4 lug = back.
I would like to upgrade the brakes to 5 lug and z32 all the way around.
I was looking around and found
http://www.n-e-c-c.com/beta/showthread.php?t=12556
S13 5-lug conversion, front and rear spindles with rotors and front 20mm spacer - $440
Since I only need the rears, what would I exactly need to convert my rear 4 lug to a 5 lug.
What exactly does the conversion consist of?
If I bought the rear spindles and rotors + 20mm spacers if TyPhOOn still has them, could I use that conversion + add z32 rotors, pads and calipers onto of it?
Btw, this isn’t Sam.
I’m quite new to brakes and just need some help.
Thanks.
“If I bought the rear spindles and rotors + 20mm spacers if TyPhOOn still has them, could I use that conversion + add z32 rotors, pads and calipers onto of it?”
= yes
http://my240.epijunkie.com/5_Lug_and_Z32_Brake_Conversion
the rear calipers don’t hook up to the stock e-brake lines though, that will require some modification.
And your list also needs Z32 conversion brake lines.
