hey guys,
need help, how do i remove my brake rotors??? they’re all seized up…rusted…HELP!
i’ve been hammering the sh!t out of it but it won’t even budge…anything i should try?
a torch…
torch and 8lb sledge…
or just thread a bolt in and torque it off.
I used a sledge.
^— easiest way is the thread a bolt else the latter.
thread a bolt into where?
there’s two extra holes where your wheel studs are, put a bolt into those holes and torque it down…
cool! thanks!
do you know the bolt size?
the rotors are rusted on? Its a floating rotor it just slides over the wheel studs. OHH is it rusted to the hub?
Make sure you clean the hub surface off really really well when isntalling the new rotor. Brake cleaner is your friend.
yeah its rusted to the hub…i told you about it last time andrew…
wd40 didn’t work
yeah now I remember, yeah try that bolt trick thro the two open holes on the rotor. If that doesn’t work just take the hub off and break out the vice grip and chizzle hehehe
