k so time to rebuild by ca… its just under 200k been a great motor and been beaten up pretty good, i have lower compression in the number 3 cylinder… currently the motor has basic unrestricitve exhaust, intake, fmic, t28bb, boost controller just at 9 psi
so far my plans :
head -
arp head studs
head gets sent off to the machine shop - valves , guides etc
gasket kit - cometic full upper and lower kit, oem ??
water pump - oem, aftermarket, seen a few on ebay ? lot of parts are discontinued from nissan canada
timing belt - oem, greddy?
oil pump - oem , seen various on ebay ?
bottom end -
knock the piston out - clean up the walls as long as there is no damage.
piston rings - oem, aftermarket ? wanting to keep the same pistons and rods and crank
main thrust washers - oem or aftermarket ?
555 injectors - already have
upgrade maf… 300zx
nistune… need to order
= 300 whp ?
please feel free for any suggestions of parts, suppliers, hints, tips etc
thanks!!
