1990 talon AWD (but it’s more anyone with any experience with OHC setup)
well after the car didn’t start for the third time we pulled the motor and took it to a shop. here’s rundown on this car:
- tensioner pully siezed, melted belt
- had head rebuit, started for 20s then bent all valves
- had head rebuilt again thinking problem #2 was a belt skip put the head on the car tried to fire, no luck, compression test - 0 comp.
so we took the whole motor and head to the guy that built the head in the first place, timing marks line up, crank pully key still in tact, all 16 valves bent.
here is the diagnosis. the intake valves opened, then when closing they didn’t close all the way so the exhaust valves got caught and then tried to close but couldnt and bam pistons hit them. (this is on initial startup mind you)
his theory: the lifters aren’t seating…but yet we had the head set for 2 days before we put it on the car for this very reason(even after we cleaned them and didn’t prime them for this reason too) the valves were closed and we turned the motor over by hand at least 20 times to check, i highly doubt i could turn the motor over with valves that aren’t closing all the way.
the guy has been on the phone with mitsu for the past 3 days while putting the motor back together (reputable shop out here, years of engine work) trying to blueprint the motor to find the problem.
any thoughts that i can relay to this guy on things to check?
