Im planning on buying a timing light so that I can find out where my timing is set at the moment. What is the default timing for the ka24e engines and up to how many degrees can I adjust it???
You mean Ign. Timing?
Stock is 15deg BTDC.
If you run 91 octane you can bump it to 18 no further…
